1 - 20 of 21 Posts
Greetings
This may be my first post from a long time lurker.
Just picked the above Ariens from a neighbor but it is missing a number of parts and I am trying to determine if it is repower candidate,
Missing the engine, crank pulley, pulley cover and complete chute rotating mechanism(crank, stand off, worm gear etc)
My first concern is wondering if the original 6 hp Tecumseh was a dual crank engine? Model # H60-75376M.
It appears I made the pick one week late on the balance of parts. Was thinking restored this would compliment my mothers uncles old 924039 sn 000483.
Great forum and thank you in advance!
Red
Sent from my iPad using Tapatalk
Discussion Starter #2
Just as I finished posting my neighbor stopped by to talk about the blower. He mentioned the original Tecumseh was dual crank. The engine threw a rod a few years ago so he pitched it but he may have some of the missing parts.
So now my question is there any way to repower this with a single crank engine.
Thank you!
Red
You must have been typing when I was:smile2:
The problem is the cam pto runs half speed and opposite direction of the crank. The transmission is designed to run opposite, so you end up with all your forward selections being your reverse and forward is limited to the one or two reverse. On some MTD style machines there's enough room inside the tractor housing to flip the trans or cut the shift lever and reweld it flipped 180 degrees to regain the same speed selection slots for your shifter. On Ariens, they are very congested inside the tractor body and usually very specific spring mounts and similar attachment points for other items, so it's not really worth the work. Check your local CL for another Tec dual shaft or someone here may have one near you.
might want to post where you live so if someone here has a dual shaft motor and won't ship it you can go pick it up
I have a 6hp on a 922 series available. PM if interested.
Just old news. Fearlessfront seems not to have learned from his former time out so he's gone. RIP
Sorry to the OP for the drama.
Seems to be a number available locally but perhaps due to season they are selling for the price of a used machine.
We will see what I find over the coming week/months
Thank you
Red
No Problem, One is Here if You Want it. LMK.
Discussion Starter #15
Bringing this back up
I’m looking at the gear selector lever
What would happen if I bent the selector lever to reverse the function?
Thinking the friction will won’t like it?
Any thoughts?
Thank you
Red
Discussion Starter #16
Actually looked at the impact on the friction disc and see that I would potentially get fast reverse and slow forward as it does not appear I can adjust the friction plate enough
TY
Red
Discussion Starter #17
Perhaps I’m lucky
Found this 5hp for 25$
Seller mentioned the short block was new 6-7 years ago
Wrong drive pulley but I’ll work that out!
Now I need a drive belt cover and a chute control gear and linkage with handle
Anyone know of a good tall chute mod?
TY
Red
Discussion Starter #19
I was able to weldless install a much later chute on my 924039
Looking for a taller chute than I’ve seen on any 924
Thank you
Red
Discussion Starter #20
I am hoping someone might be kind enough to measure the base plate thickness on a late 70’s HS50
The one I acquired appears to be a later version
I needed to remove the stud spacers and now have potential interference between the auger pulley and idler
TY
Red
1 - 20 of 21 Posts
