Howdy All,
I was given a 1981 Toro 421 snowblower. The snowblower had been recently serviced and has new belts. The previous owner said it lost spark. So he removed the flywheel to investigate the points to find out mice did a number on the ignition wiring! He reinstalled the flywheel and snapped the threaded end off the crankshaft. If anyone needs parts off the 4 HP engine let me know.
So I installed a newer 5 HP Tecumseh off a Craftsman snowblower. It has a brand new OEM Carb and no points to mess with now! The engine swap went well with a couple of issues to overcome. The original 4 HP has a 1" PTO Crankshaft diameter and the 5 HP has a 3/4" PTO Crankshaft diameter. So I went to my local mower shop and they had a used crankshaft pulley off a Toro 3521. $22! It's perfect! It was the right diameter and my belts line up perfectly. No shaft adapters needed.
Yesterday I installed the engine replaced the fuel line, primer line, and fuel filter, I put oil and gas in it and it fired right up! Runs great! I want to use the electric starter off the 4 HP on the 5 HP. It looks like it will bolt on to the engine, but the two starter switch mounting holes are orientated different than the holes on the 5HP starter shroud. On the switch the two holes are across from each other left to right, and on the 5HP starter shroud they are offset. I don't want to drill new holes in my fan shroud if I can get away with it.
So my questions are:
1. Should I just replace the starter with one that is spec'd out for this engine? Part number 333290E.
2. If the 4 HP starter motor is compatible, should I simply replace the starter switch assembly with the correct one for the 5 HP engine and just reconnect the wires to the old 4HP starter motor?
I am also considering adding a Toro 521 Tall Chute to replace the short chute that's on it now. Will doing this help with it's throwing distance? Is the 521 Tall chute all metal?
I have a new scraper bar and skid shoes arriving tomorrow. I am going to pull the old ones off today in preparation for the new ones. I still need to wire the original kill switch to the 5 HP engine.
I appreciate any comments and help!
Hec
Hec
