Slightly off topic but I know the info is here so...
Unit#1: Toro 25cc string trimmer, about 9 years old
Unit#2: Jonsered blower about 8 years old.
Both won't start today, had been running in the last 3 days.
#1 was running really rough at low speeds.
#2 ran fine about 2 weeks ago.
#1 Replaced carb, spark tester shows spark, plug out of engines shows spark, tried new plug, tried starting fluid. No firing in any case. Checked compression: about 50 - 55psi. According to MTD manual found on line indicated minimum should be above 80psi.
I am am thinking internal engine damage.
Your opinion please.
#2 Replaced carb about a year ago had been running fine since. Today spark tester shows spark, plug out of engines shows spark, tried new plug, tried starting fluid. No firing in any case. Checked compression: about 50 - 55psi.
I'm assuming same problem as #1
Another blower using same oil-gas mix continues to start and run normally. I really don't think it is a fuel problem.
Thanks in advance for any info.
Burt
Burt
