1 - 2 of 2 Posts
I replaced both drive belts because they were showing signs of wear and ever since then I cannot adjust the cable to fully stop the machine.
3rd and 4th gear are ok but the machine '' walks'' in 1st and 2nd.
I rechecked the belt part numbers and they are the correct toro belts the only thing I can think of is the belt tensioner idler spring is weak and not fully releasing or I reinstalled the idler assembly wrong.Again I had no problems untill belt replacement.
Auger works as it should just the traction control.
Thanks in advance.Paul.
YOU ADJUST THE BELT TENSION WITH THE NUTS UP BY THE RIGHT HANDLE. RUN THEM DOWN TO LOOSEN THE BELTS. IF U NEED MORE HELP??? LET ME KNOW!!!!!!!!!!! MAHALO:cool:
1 - 2 of 2 Posts
