From NW of Boston…visit this forum every week for years. I don’t know very much about fixing motorized equipment-so don’t post suggestions, but do enjoy reading the posts—and the banter between many of you.
Have a 2008 Honda HS1132 Trackdrive, it has been very reliable for me. Do regular maintenance on it, oil, spark plug, also (done twice) replaced both auger bearings, the impeller shaft bearing, and both belts….had to take the bucket off-went surprisingly well. Someone on this forum welded up the bucket skid brackets a few years ago for me-he did a great job!
Snowstorm yesterday, while blowing the driveway, everything was seemingly working well…then the drive system ‘failed’. Just stopped moving. I wear earplugs, I did not hear any grinding noise, no jerky movements etc. It just stopped moving forward. On a very steep driveway.
Once I got it back in the garage, I went to this forum, and searched for HS1132 and drive issues. Found many great posts-went back to the garage, and started going down the list.
The machine/engine was cool.
Checked the hydrostatic fluid level. Was midway between the high and low.
(I did not removed cap & the cup).
I moved the engaged / release lever, it moved a shaft which moved in and out (of the transmission?).
Removed the chute, the headlight, and the pulley/belt cover. At first glance I thought that perhaps the belt had stretched….but I started the engine, and safely engaged the drive lever:
the large wheel driven pulley spun;
the axle going to both the left and right tracks spun in both forward and reverse.
Turned engine off; then I lifted the back end off the ground… so supported on the bucket scraper bar, and on the black piece of metal on the very back bottom…so I could move the tracks. I spun the right side….and the left side track spun with it (they both moved/spun).
Does this mean that the axle pin(s) are broken? Or hopefully there is something easier to check and then fix?
Would draining the hydrostatic system (checking for air bubbles) be a likely fix?
Before this breakdown, was hoping to keep this snowblower because it has worked well for me….and honestly, newer products seem so complicated….I worry about fixing/having them fixed in 5 years; or 10 years. This snowblower was bought new in 2008.
Suggestions? Thoughts?
Thank you very much !
