28 Pro Hydro RapidTrak 1st thoughts
32K views 108 replies 27 participants last post by  mctwist
We've now had about 40" of snow since early October. I've had a chance to run this new blower a few times in the last week or so and get acquainted with it. I just did another 8 inches and some plow stuff. More snow coming tonight.
My perspective on this new machine may not be as accurate as others because I had the same old durable 1236 for 28 years. In that respect I'm a little out of date for everything in between 1990 and 2018.
That being said I like this new machine a lot. The engine is very quiet to me. Of course I had the original muffler on the 1236 and was probably running a straight pipe the last many years :) I like all the controls and how they work. Hand warmers are something that should have been added to snowblowers around the same time they came out for snowmobiles. (maybe they were?) These warmers take a while to get up to speed, but work well enough to wear light insulated finger gloves. The hydrostatic tranny works slick! The chute controls are heads and shoulders above what I had!
The track set up is well thought out. If it has any drawbacks it's that the entire mechanism is exposed to the elements. That could be problematic if a machine had to be kept outside. I had one small issue last week with a small bit of ice hanging things up a bit while in the wheeled position and dropping the track in the garage. That issue easily resolved itself once It started moving and bumping around. Our machine will always be garaged albeit close to the big door where it's a little drafty and will go below freezing in below zero temps outside. One thing I do like about the way the track mechanism is designed is that the vertical bar everything moves on has some play in the sliding mechanism. This could mitigate the freezing problems I just referenced. I'll never know. I'm sure Ariens took this into account when they were designing this unique set up. One of the reasons I went this way was the ease of maneuverability in the wheeled position and the auto turn feature. They both work very well! My initial comment in another thread on the 'floating' lowered track position was wrong. If you release the lever from the wheeled position (as the book says) it does stay floating until you slightly lift the handlebars if stationary. ...then the whole track locks down and also applies more weight to the front end. My limited use so far shows the track will lock in by itself once you start moving forward and bounce a bit. Enough weight transfers to the front end in this position that it can cause the tracks to spin. The dig position has a slight trade off in track footprint because in order to xfer max weight to the front of the machine, it lowers the back bogeys below the front wheel height. This lifts the front wheels about 3/4" off the ground. The added weight to the front is measurable and it digs in well. This position can also cause the tracks to spin if encountering tough stuff. I experimented in all 3 modes today. All worked well and I found the wheeled position to work just fine where there were no car tracks to clean up.
I've not run into a heavy snow situation yet that would potentially bog the engine down and don't expect to...no matter the load I bite into. The only way my old 1236 would bog is if I was cutting into a drift which covered the muffler. Other than that it would chew snow till you stopped. It was a beast! This machine is 8" narrower and a HP or 2 more. I'm expecting good results from heavy snow...like a 2-3 foot storm. This machine chucks snow very well so far.
The 1st pic is the dig position with the front wheels lifted up. The 2nd is the sliding track mechanism vertical bar. The 3rd is from around 1996 at our old house. Might have been the 320" year. The old 1236 took care of it. The 4th pic is from our house last year on 4/20. Got some heavy snow the 3rd week of April last year.
#88 ·
I said my piece on the gas shut off, but....I have to share what the machine just did. Last year in February our furnace went out while we were 2000 miles away. I have several back up plans in place one of which is my phone going off when this happens. I called my furnace guy. He said he'd never seen a storm with wind swirling the way it did and to check my furnace inlet / out pipes on the back of our house. Sure enough, they were plugged. This has never happened before. Normally the exhaust is enough to keep an area melted in front of them. The lad across the street that takes care of our house for us had to trudge through 3 feet of snow to get at it to shovel
I decided to make his life easier in case this happens again this winter. We've gotten 70-75" of snow so far and what I chewed through has set up since the beginning including an extremely heavy wet dumping Thanksgiving time. I wasn't sure exactly how the Rapid trak would handle this, but I was amazed to say the least. It was a bit tough turning given the snow was as high or higher than the bucket the whole way through. I chewed through 115 feet and around the house in less than 20 minutes. Very impressive. I would have been bulling my old 1236 through there for a LONG time.
One pic shows my plugged pipe from last February and the rest are today's handiwork
#91 ·
You sound just like me. I kept changing my mind every day, back and forth, Honda 32" or Ariens RapidTrak. Couldn't decide. I'd put one machine in the cart, than change my mind. So much so, I ended up shoveling our first snow storm because of my indecisiveness. I finally pulled the trigger on the Ariens with the LCT motor (926078) and smaller gas tank. I originally wanted the B & S 2018 model (926060) with the larger tank, but they were all out of stock. Paul on YouTube just did a video on the RapidTrak with the LCT motor. He had or has the 2018 with the B & S motor too. He stated he see's no difference between the two running them and gets 90 minutes with the LCT motor. Said it uses less fuel. I'd assume the B & S would get close to 3 hours run time per tank than. I'm not a using mine for business, so 90 minutes in between refills works just fine for me. In fact, I believe it will actually help me in that I'll have fresh fuel all the time (lol). I also like that with the Ariens (LCT) motor, warranty is all done thru Ariens dealer. With the B & S, motor warranty goes thru Briggs while machine warranty goes thru Ariens.
#92 ·
Honda n CNY, your experience with the 1332 was basically the deciding factor, thanks for your honest reviews on the two machines, greatly appreciated!
BNSFguy, I was exactly in the same boat as you, I too went with the 92078 for the exact reasons you did and this dealer added the two year warranty extension.
Just waiting on delivery!
#94 ·
We end our winter this year with about 90-95 inches of snow and another successful Rapid Trak season. I like it more all the time.
I had one very minor issue which happened last week. I mention it so others can maybe make sure their pins are are well seated. You can see in the picture two black cog type things on the end of the shafts for the Trak drive and auger engage control. I don't know how, but I lost the pin out of the auger side one and was not able to keep the Trak moving with the auger turning without it. These two cogs engage each other when the levers are both down allowing you to take your hand off the auger control to maneuver the chute if needed
I was going to just put a small cotter pin in there when it happened, but the dealer is a only a few miles away. It was 10 second fix. I also attached the pic because the two cogs need to be in this orientation to work. They are basically 180 degrees out from each other on their respective shafts
#96 ·
I actually tried to reverse these cogs on my machine. As you know, holding down the drive handle keeps the auger handle engaged due to the orientation of the notch. I thought it might be more handy to have the auger handle be the one that kept the drive down, so that I could use my left hand for chute control. This only make sense, so one doesn’t have to cross over with the right hand to move something on the left side. Alas, It didn’t work. I’m sure someone thought this out so people like me can’t change the design.
#98 ·
Originally, I too, was looking for an EFI 28" Pro RapidTrak and saw they don't have them available in the US. After doing more research I'm actually glad I don't have an EFI. EFI probably is the future, but just doesn't seem perfected yet. Not sure if that's because Manufacturers are trying to keep costs down so they can sell them or if it's just new technology and their still figuring out the "bugs". I'm glad I have a carburetor motor, at least for now. Maybe a few years from now I'll be interested in an EFI version, but just not yet.
#103 ·
Yes last Tuesday we got about 4-5” of some real nasty stuff, had a 3’ EOD berm and it performed above my expectations, love the tracks and hydro, will never go back to disc and wheels, the auto turn worked perfectly and love the quick turn chute, only got to use it the one time but can honestly say there’s nothing I dislike about it and I’m comfortable knowing there’s nothing this tank can’t handle!
Have you used yours yet?
#104 ·
I just added this post in a New member introduction thread. Thought it could be placed here in the Rapidtrak discussion as well so others can read my review, and comment. I have a 2019 model Pro 28 Rapidtrak Hydro EFI.
It's been a while and I have tested the machine quite much. I would say that the autoturn does not work at all in track mode. In fact I tend to go back reverse and run a new pass instead of turning the machine, because it is so heavy. I could jump to wheeled mode, turn and then go back again to track mode, but it is maybe a little compex because you also want to turn the chute the same time. It of cource depends on how long the pass is, but on my terrace which is about 50m2 I do much reverse driving. It seems like there are different definitions of tracked mode. I call it tracked mode when the track is locked in a fixed position. There is also a position if you just pull the leaver when being in wheeled mode so that the tracks are in contact with the surface, but not locked down. Then the autoturn works, but I have not used this mode much because it just jumps into locked position if the surface is a little uneven.
I would have liked more speed in reverse because it is quite slow. It also feels quite weak in reverse, for example uphill, but it might be something that needs tuning. I am not sure.
About the different modes I think that track mode is the only mode working for me. In wheeled mode it is very easy to turn around, but the machine wants to climb up all the time. I think the weight balance is poor and there should have been more weight on the front. Dig-in mode is useless because you loose tracktion as a lot of the belt is not in contact with the ground. I have been thinking about buying some larger skid shoes because the machine feels a bit jumpy on uneven surfaces.
The EFI engine is very nice. As long as the machine has tracktion it eats up any snow. I trickle charged the battery two times during the summer period to keep it fit and have not experienced any issues with the engine. It started on the first pull this winter. The fuel tank is a little small, but not a major drawback.
In summary I am pleased with the machine. The engine and build quality is super. The belt tracktion is ok, but not perfect. It is slow in reverse. Looking at videos of Hondas and Yamahas they seem more stable and not so jumpy, but I have not tested any of those so I don't know how they compare to the Ariens.
#105 ·
I thought I saw this same picture used on the Ariens Facebook page.:smile2:
Regarding turning while in regular track mode I sometimes pull back on the bars while I turn, making the tracks spin. That allows me to get tight turns without going in and out of wheeled mode. But it takes some getting used to.
For dig-in mode I am in agreement with you. There's just too much force on the bucket for the track to not spin. And it gets worse if going up-hill.
I've considered putting ice studs on the tracks for this, but that could have the negative side-effect of making tracked turning harder. I'm considering adding a new track setting that is in between dig-in mode and track mode. I would add a notch to the track bar. I put a picture of how I can use a C-clamp to play with different settings before committing to making the new notch in the track bar.
See:
https://www.snowblowerforum.com/forum/1724883-post30.html
Regards,
Eric
#107 ·
You can adjust the track release sensitivity the dealer tells me. Mine came 'less sensitive' from the factory. At first it had me confused as to why it would sometimes lock. Now I find it much better to have to lift a tad more to lock the track. When backing up, I just hit the release lever and we're back into easily turning. It won't lock as easily as you're relating. Even in dig mode, I do the same to back up. I accept the limitations of dig and use it accordingly. I can peel up car tracks in dig mode (within reason) going downhill. I keep the tracks spinning just a little ahead of the traction point. Works well for me.
Short of the added notch solution, Ariens should probably advertise the machine as a 4 position unit and expend a little more ink in the manual explaining it all. My manual says nothing about having to lock in the normal track position by lifting a tad.
