101 - 109 of 109 Posts
Yes last Tuesday we got about 4-5” of some real nasty stuff, had a 3’ EOD berm and it performed above my expectations, love the tracks and hydro, will never go back to disc and wheels, the auto turn worked perfectly and love the quick turn chute, only got to use it the one time but can honestly say there’s nothing I dislike about it and I’m comfortable knowing there’s nothing this tank can’t handle!
Have you used yours yet?
I just added this post in a New member introduction thread. Thought it could be placed here in the Rapidtrak discussion as well so others can read my review, and comment. I have a 2019 model Pro 28 Rapidtrak Hydro EFI.
It's been a while and I have tested the machine quite much. I would say that the autoturn does not work at all in track mode. In fact I tend to go back reverse and run a new pass instead of turning the machine, because it is so heavy. I could jump to wheeled mode, turn and then go back again to track mode, but it is maybe a little compex because you also want to turn the chute the same time. It of cource depends on how long the pass is, but on my terrace which is about 50m2 I do much reverse driving. It seems like there are different definitions of tracked mode. I call it tracked mode when the track is locked in a fixed position. There is also a position if you just pull the leaver when being in wheeled mode so that the tracks are in contact with the surface, but not locked down. Then the autoturn works, but I have not used this mode much because it just jumps into locked position if the surface is a little uneven.
I would have liked more speed in reverse because it is quite slow. It also feels quite weak in reverse, for example uphill, but it might be something that needs tuning. I am not sure.
About the different modes I think that track mode is the only mode working for me. In wheeled mode it is very easy to turn around, but the machine wants to climb up all the time. I think the weight balance is poor and there should have been more weight on the front. Dig-in mode is useless because you loose tracktion as a lot of the belt is not in contact with the ground. I have been thinking about buying some larger skid shoes because the machine feels a bit jumpy on uneven surfaces.
The EFI engine is very nice. As long as the machine has tracktion it eats up any snow. I trickle charged the battery two times during the summer period to keep it fit and have not experienced any issues with the engine. It started on the first pull this winter. The fuel tank is a little small, but not a major drawback.
In summary I am pleased with the machine. The engine and build quality is super. The belt tracktion is ok, but not perfect. It is slow in reverse. Looking at videos of Hondas and Yamahas they seem more stable and not so jumpy, but I have not tested any of those so I don't know how they compare to the Ariens.
I thought I saw this same picture used on the Ariens Facebook page.:smile2:
Regarding turning while in regular track mode I sometimes pull back on the bars while I turn, making the tracks spin. That allows me to get tight turns without going in and out of wheeled mode. But it takes some getting used to.
For dig-in mode I am in agreement with you. There's just too much force on the bucket for the track to not spin. And it gets worse if going up-hill.
I've considered putting ice studs on the tracks for this, but that could have the negative side-effect of making tracked turning harder. I'm considering adding a new track setting that is in between dig-in mode and track mode. I would add a notch to the track bar. I put a picture of how I can use a C-clamp to play with different settings before committing to making the new notch in the track bar.
See:
https://www.snowblowerforum.com/forum/1724883-post30.html
Regards,
Eric
See:
Regards,
Eric
Hi Eric,
That sounds like an interesting project. Please let us know how it goes :smile2:
Discussion starter · #107 ·
You can adjust the track release sensitivity the dealer tells me. Mine came 'less sensitive' from the factory. At first it had me confused as to why it would sometimes lock. Now I find it much better to have to lift a tad more to lock the track. When backing up, I just hit the release lever and we're back into easily turning. It won't lock as easily as you're relating. Even in dig mode, I do the same to back up. I accept the limitations of dig and use it accordingly. I can peel up car tracks in dig mode (within reason) going downhill. I keep the tracks spinning just a little ahead of the traction point. Works well for me.
Short of the added notch solution, Ariens should probably advertise the machine as a 4 position unit and expend a little more ink in the manual explaining it all. My manual says nothing about having to lock in the normal track position by lifting a tad.
Instead of "lifting a tad", I find it easier to simply tap down on the bar lowering the rear tracks with my foot. Does the exact same thing. You don't need much pressure, just a tiny bit and it locks in place perfectly. Both work fine. Just preference.
This is also what I do, as I find that lifting would not always lock it in position.
Sent from my Pixel 3a using Tapatalk
