Hello, While priming 3X 26" TRAC it leaks fuel from bottom the recoil assembly. Plugs are dry.
Can someone refer me to a shop manual so I can fix or offer tips. Seems I need to remove plastic cover from around the gas tank/recoil to get access to the leak?
1. What is your actual model number/serial number? Is it 31AH5DVA710? If so, follow the link below for your manuals.
2. How many times are you pushing the primer? Per the engine manual:
  • Prime 3 - 5 times.
  • Make sure you cover the vent hole with your thumb.
  • Hold the primer bulb in for one full second each time you press it.
  • NOTE: DO NOT use the primer bulb to restart a warm engine after a short shutdown. Doing so will flood the engine and may result in equipment malfunction.
Does Cadet offer service manuals to the public for late models? Its too heavy to haul to the repair shop when its not running.
In this case, what you may need is the engine service manual. Since MTD / Cub Cadet doesn't make their own engines, you need to use your engine make/model/serial info to look things up.
Is it a type 683-WUB? Get the real model/serial numbers off the engine. You still have not confirmed your machine model number either...
