1 - 3 of 3 Posts
Hello. I just bought a new 524 SWE snow thrower and a heated grips kit. I started at the top installing them and worked my way towards the engine and everything was going smooth until I went to plug the new wire harness into the engine harness. My thrower has a four wire plug. The grip kit harness has a two wire harness. None of the included adapters will work either. After spending about thirty minutes on the phone with cub cadet, they told me they couldn't be installed on my thrower. The original wire harness only used two wires for the headlight. Does anyone know how I can hook these up?
Thanks.
I installed the heated grips on mine last year, and just used the adapter that came with it. I'll double check what my wiring set up looks like and see how it's different from yours. What is the part number from the grip kit you used?
1 - 3 of 3 Posts
