There is some info on parts on Searsparts, no manual. I also think you're off a decade or 2 on your estimation of age, I believe it's more like 50's or 60's personally.
Thanks, you are probably correct on it being a 1960's era. It was my neighbor's when I was a kid. My sister got for him and I took it once they lost the bolt holding the reel on. Fixed it up and it still works but the engine is showing its age. I am re powering it with a 6.5hp Predator engine. I've seen some videos where they talk about changing/drilling out the jets. does anyone know where to look for the how to info on this ? thanks.
I just know what I read on here. HF sells a set of micro drills. You drill out with the next larger size or two.
Just got the time to mount the Predator to the chassis. The old clutch broke while trying to remove it. I am going to use a go kart clutch. Does anyone have an opinion on using a clutch with holes in the face for cooling or should I buy a solid face one like the original? Just worried about the clutch freezing up.Also to consider is that the open faced ones have set screws plus a keyway while the solid faced ones use a keyway and a retaining bolt on the end of the shaft. I am worried about the clutch floating out of alignment with the sprocket and throwing the chain. Any help would be appreciated. After this I am going to try a heater box conversion from one of the members.
