1 - 2 of 2 Posts
Could not start my Toro 621e with fresh gas for the first time. Purchased a carb kit, cleaned carb and installed new float and needle and still would not start. Turned out to be carbon fouled plug and it started and runs fine after I cleaned spark plug. I wanted to say do not assume hard starting is fuel related without first checking the spark plug! Lesson learned
glad you got it going. Are you sure it wasn't bad connection to the spark plug? Usually a fouled plug will at least try to start. Regardless, you should be good for a while now. And yes, lesson learned.
1 - 2 of 2 Posts
