1 - 2 of 2 Posts
The owner’s manual indicates adjusting the skid so the auger is 5 mm above the ground. It also indicates to adjust the scraper so it is 5 mm above the ground. That makes the auger and scraper on the same level. Does not make sense to me.
I think the scraper should be between the skid and auger. Maybe they should all be 5 mm apart?
Why? The skids should be the only thing touching the ground and the scraping blade even or lower than the auger blades. Now if the scraper was higher than the auger I would think ***!
1 - 2 of 2 Posts
