I have both of machines 536.918400 8/26 & 536.918900 10/32 Just interested if there is a real differences
in belt sizes? for auger & drive belts. Looking at sears parts direct, the belts for auger and Trans drive are different
for 8/26. (Auger Belt) 49581MA 36.7 inch raw edge (Trans Drive Belt) 49570MA 37 inch.
But the 10/32 both belts are the same 51304MA 37 inch. which I had the impression most of the other driftbreakers models with actual peerless transmission units used 37"inch belt. Anybody else run into this issue, when replacing belts.
Or does it even matter since these are just equivalent for replacements offered by Sears/briggs. I need to replace them
after last weeks 14" of fresh lower Michigan Snow. They both chewed thru good until the end, could hear auger belt slipping. I have not touched the belts on them yet.
I read a bit from this forum, that HCBPH has posted about these machines. I have other 1? I need to replace the plastic
axle bearings on the 10/32 , what can be used to align the new bearing with (The 4 hole bolted cast block bearing) he used on his. I don't own a lathe. But need to replace them, the plastic bearings are cracking around bolt flanges. Can the older 10/32 clamshell with bearing be adapted? or is hole the hole pattern different? I have spares from a parts donor machine. But would like the roller bearing better, to move these heavy monster's around a little easier.
