Thanks Chevy88, I appreciate it - I'll wait for your photos before ordering the $56 part. I don't want to buy it if it's not what's being used on these machines.Going to be a rainy couple of days and my chipper for the moment is outside under a tarp. When I get a good day I’ll go out and check on some things and at the very least take a few photos of what I have.
You won't see the governor in action without the engine running. A mechanical governor uses flyweights to create a force based off of crankshaft speed which is balanced by the force of the governor spring. The top engine speed is varied by increasing the spring force to run faster or decreasing the force to run slower. The governor spring wants to open the throttle and the governor tries to close the throttle. The interaction of the governor spring and mechanical governor holds the throttle at the desired engine RPMs based upon a force balance and the load / operating conditions.1. What makes the Gov move when the Throttle is increase? Is the the blue spring dead, or is there a spring or some sort of linkage missing?
2. What makes the Gov move back when the Throttle is decreased?
