Greetings. I'm just curious about something.
I started dissembling a bucket from a Ariens model 924039 that I purchased to put the guts into the bucket of my 924050 (if you're in the Hartford CT area and looking for a 924039 tractor minus the motor I can put you in touch with the guy).
The sticker in the 924039's bucket states that it is a model #824001. Doing a web search I see that the 824001 bucket is for a tractor with small wheels whereas the 824002 bucket is for a tractor with large wheels.
My question is: does anyone know what the physical difference is between the two?
TIA
K
24" Augers of the same Shape and Series Should Interchange. The Guts of an early Round 924 bucket will not fit the Square Bucket IIRC.
Hi Jack, yes I do recall your saying that in an earlier post. I was just curious what the physical difference is between a square bucket for a large wheeled tractor and a square bucket for the small wheeled tractor.
It is mentioned in this PDF on the first page.
http://apache.ariens.com/manuals/024386A.pdf
K
At first I wondered, to myself, "where did you see that? I have never heard of such a thing before.." then I thought..uh-oh, where would it likely be? ;) yep:
https://scotlawrence.github.io/ariens/Page7.html
(its my own webpage!) ;)
That info was pulled from Ariens owners and service manuals. Its a very rare notation that Ariens designated specific bucket models to go with specific tractor models. Its so uncommon, I forgot it even existed! ;)
I would say its 99.999999% likely that the buckets are completely identical, and either bucket model can go with either tractor model..why Ariens made that specific distinction back in the 70's I dont know, but history shows that the same bucket has always been used across an entire "series"..one bucket model fits many different tractor models.
Yes, I did come across your page as well, very nice. I also found it referenced in Ariens documentation, in the link above.
Thanks for the input.
K
