Hi all - New to the forum...hoping you can help me get this beast back running correctly again.
I am hoping someone has a picture of how the linkage goes back together. The Sno Thro has a 10hp tecumseh HM100 - 159024C. The carb has two throttle rods on it that go back to what I assume in the governor arm of the front (thrower side) of the engine block.
I took the carb off to clean it and it was full of crap. Every thing runs now but only if I stick my finger in and turn the throttle manually. The carb linkages don't seem to be put on correctly.
Does anyone have a picture of them on correctly....?
Thanks again
The first link has like 15 different videos. I just picked the one I assumed might be right. Maybe one of his other videos is a better match for your setup.
Well. It turned out that the smaller of the two rods was bent incorrectly and once I bent it back so it would clear the intake runner it worked fine. The old beast runs great. Now if we only had some snow.
Thanks for the help.
