1 - 3 of 3 Posts
I have an Ariens 920014 Compact 24 LE with an electric start that plugs into a 110V outlet with a push button to engage.
However, it now engages and starts the instant it is plugged in. No pushing of the rubber starter button required.
What to do to fix?
What to do to fix?
My guess is, you got a defective switch, if so, replace it.
HTH
JerryR
sounds like the switch is stuck, That has a briggs engine so it may not be too bad to replace if you can't fix it. Could try and take the switch housing apart and see if there is anything obvious making it stick in the on position.
1 - 3 of 3 Posts
