Well here in what at times has been a major snow fall area, Central NY, I did fire up one of the good old Ariens more or less to make sure it was ready. Had maybe 1.5 inches of rather wet stuff. The discharge chute did plug up a few times when switching direction but otherwise worked good. Maybe the next time there is some I'll give the other one a test run as well.
I knew either one would run good as a few weeks back I had fired them up and did the annual oil change. They did need a little carb cleaning basically drop the fuel bowel and a quick shot of carb cleaner. I have tried running fuel dry, leaving gas in tank with Stabil or just top off the tank after last use in spring. To be honest no matter what I have done they always need a little something to get them to fire up in winter also takes a tank of fresh gas run through them to get them sounding good.
These both have been converted to 15C 107-0040-F8 Briggs snow engines.
