1 - 2 of 2 Posts
Hi folks,
I forgot to tighten the allen screw on the impeller pulley housing watchamathingy.
I pounded it on so I don't think it will come loose. The key was partly squashed and this is why I went on with so much difficulty.
Your thoughts?
Thank you and happy blowing!
Sirdonald
Fix it.
Use a puller if you need to but get the hub off the shaft and replace the key with a new one. They're very cheap. Put some anti-seize on the shaft too. Then tighten the set screws.
You know when it'll come off if you don't fix it.
1 - 2 of 2 Posts
