Hi Guy's
My Ariens 24 sho 921038 from late 2014 has a 60watt rated motor with both a halogen light and heated hand grips. I snipped the wires to the old light and added a bridge rectifier and installed an 18w LED light. The old light had a 20watt rated bulb so I thought a 18watt led light would be good enough. The light works great, but I had to buy two led light from Amazon. My question is can I add another led light and splice in to the wires to the bridge rectifier. I then would have 36watt of led light replacing 20watt of ac halogen light. Will this cause a burn out of the electrical system since a believe the heated hand grips are 30-35watts and the 36watts of LED lights will add up to 66-71watts on a 60watt rated motor? I could also keep the other LED light as a spare. Any help would be great. Thanks
Hi Guy's
18W rating does not necessarily mean 18W at the output voltage available from your stator.
It seems quite a few of the advertised/sold LED lamps are rated for voltages that go as high as 24 or 30V DC and being that Volts X Amps=Watts, there is no telling how much current they will draw when hooked up to your machine- it will depend on the voltage output of your machine when loaded with the heated grips AND the LEDs.
If you want to use the heated grips And 2 18W LED lamps at the same time, the short answer is, you will have to hook it up and monitor the AC current it draws from the stator to find out.
Here is why.
Based on what I measured on my Ariens (also equipped with a 60W stator), with both halogen lamp and heated grips ON, the total current draw was 4.2A @ 14V rms = 58.8VA while the "Volt Ampere" value does not translate exactly into Watts-it was close enough for me to take that value as the SAFE MAX (no more headroom) available.
In my case I planed on using 2 10W LED lamps rated for 12-24VDC to replace the halogen lamp. On the bench each LED drew about .5A @12V DC=6W (much less than the 10W advertised - at 24V they probably will be closer to 10W)
On the machine my measurements showed that with the 2 10W Leds and the heated grips ON the total current draw was only 3.7A @14.3Vrms=52.9VA. The LEDs only - drew less than 1A @ 15.2VDC=15W.
HTH
JerryR
Jerry, thanks for the reply. I think I need to get my voltage tester out and measure what i'm getting with both the led light and the heated hand grips on before I add another led light.
Witz
Last year I put two 18W LEDs on my blower and it works fine. It has the hand warmers and a hour meter all running on Briggs and Stratton AC power.
Maybe we have the same lights?
On my other (spare snowblower) I run 2 old school 35W halogens and when everything in on you see the lights dim slightly. If I turn the hand warmers off no dim. If I switch 1 light off no dim.
It works, but it's maxing out the electrical system.
That's why I put leds on the new machine.
I should swap them out but I'm not motivated enough because it works fine. I hate fixing something that not broken. I learned to just not turn everything on at the same time. I don't think you can burn the the windings out, but I will play it safe and not turn everything on at the same time....
