1 - 15 of 15 Posts
I just bought an Ariens 8524 and the guy told me it was about 3 years old. It looks like it has hardly been used, but I get the feeling that it is much older. How do I find out how long ago they made this model (932104). I can't find any specific info on the internet, not even a manual. Any help would be appreciated.
Thanks,
Erie_Man
Is this a durable machine and worth $450.00? It looks like it is only a year old! the muffler is hardly burned and there is hardly a scratch on it. It must have sat in someones garage for a few years!.
Thanks,
Erie_Man
  • 8524LE DeluxePuts You "in the Clear" Quickly
    The 8524LE Deluxe won't "hog" your family time.
    The Ariens® 8524LE Deluxe Sno-Thro machines are versatile enough to clear paths at any home or business. Their super-modified impeller design powers through snow quickly. So you can move on to better things.
    It's versatile enough to clear 2-foot-wide paths at any home or business. And you can expect it to work better than any other snow thrower on the market. It's powered by an 8.5 hp Snow King engine with standard 120V electric start. It features a super-modified impeller design that drives through snow and discharges it in any direction. The Snow Hog tires with special tread design provide superior traction in all conditions. Our variable speed R3Disc-O-Matic™ drive delivers six forward speeds and two reverse speeds with easy shifting in relentless conditions.
  • New R3 Drive System is a newly designed disc drive to deliver more torque at the drive wheels for reduced slip out and increased drive-system life.
  • 110/120 Volt Electric Start just plug it in and push a button. Makes getting started easier.
  • All Steel High-Profile THF Discharge Chute with deflector allows you to control the throwing distance and snow placement.
  • 8.5 hp Tecumseh® Snow King Engine engineered to work in the toughest winter conditions and comes equipped with an exclusive 3-year limited Tecumseh® engine warranty. Includes Fuel Shut-off Valve for safe transport.
  • 2.5X Quick-Turn Chute Rotation allows you to rotate your discharge chute 215 degrees with only 2.5 turns.
  • Dual-Handle Interlock System conveniently frees one hand for chute and speed adjustment on the fly while maintaining operator safety and convenience.
  • Pin-lock System Wheels offer a choice of positive dual-wheel drive in heavy snow or single-wheel drive for easy maneuverability (no tools needed).
  • Durable Aluminum Gear Case Houses a steel worm gear and a brass ring gear. Two different metals combined with specially blended lubricant, generate less heat due to friction for reliable performance and longer gear life.
  • Double-Duty Reversible Skid Shoes adjust the height of blower housing to clear uneven surfaces. Skid shoes are reversible to last twice as long.
  • Standard Headlight a recessed light makes snow removal safer. Allows for operation after dark.
  • 6 Forward and 2 Reverse Speeds allow you to select the proper ground speed for the conditions you are operating in.
  • Made in the U.S.A.
GENERAL INFORMATION
MANUFACTURER
Ariens MODEL YEAR 2004 MODEL8524LE Deluxe (#932104, 502)
M.S.R.P. *
$1,099.00
DIMENSIONS
LENGTH
59 in.HEIGHT42 in.WIDTH27 in.WEIGHT240lbs.
ENGINE
ENGINE
Tecumseh® Snow King® L-Head
HORSEPOWER
8.5 HP
STARTING SYSTEM
110/120 Volt Recoil
FUEL CAPACITY
1 gal.POWERTRAIN
TRANSMISSION (DRIVE SYS.)
Disc-O-Matic™
TIRES / TRACK
Wheel Size: 15 in. x 5 in. - 6 Pneumatic
OPERATIONAL
IMPELLER
4 Blade
AUGER
Steel/Serrated
SPEEDS
Forward: 6 Reverse: 2
CLEARING WIDTH
24 in.
DISCHARGE DISTANCE
45 ft. (maximum)
DISCHARGE CHUTE ROTATION215° 2.5x Quick-Turn
Thanks for the Information, manual and your comments. More questions; can I post pictures of this machine and how much tire pressure do you run? The tires are rated for 20# and had 2-2.5 in them when I got it home.
Thanks,
Erie-Man
Of course you can post pictures. It is practically mandatory :)
The older manuals I believe specified 12 psi. Anywhere between 10 and 15 is probably good. Experiment a bit and find the best compromise between bounce, easy of rolling and traction. The most important thing is just to make sure you have the same pressure in each side.
You can either upload them to a web/photo host and link them here with img tags, or I believe this forum lets you upload them directly as attachments.
If you upload them to a web site you can paste the link here like this:
I finally figured out how to create a photo gallery and have loaded three pictures of my new (to me) Aerins 8524. It looks pretty good to be a 2005.
Erie-Man
Thanks,
Erie_Man
I would say $450 is a very good price!
yes, it might be 7 years old, not 2 or 3 years old, but for an Ariens,
7 years is nothing..
and especially if it has been garaged and well cared for and is in good condition, I would consider $450 a good deal for such a machine..
In your first picture it looks like the bucket might have been repainted. It seems to be a different color than the drive section, and it looks like it is missing a few warning labels and the Ariens logo. It also seems to be an older design bucket, but it looks like they were made until 2004 or so on Scot's website.
The flash might have washed out the color a little bit but it good to know that I made a good investment, even it was by accident. I have one other question, I saved the operating manual that was posted but I need the engine manual to know what oil, spark plug etc. It is a model HMSK 85.
Thanks,
Erie-Man
1 - 15 of 15 Posts
