Hello, I'd like some help making sure I get the correct pullies. I pulled the HS40 off and slid on a OH195XA 71228J. The old engine has dual shafts and this one is a single. I need to figure out what pullies to order as well as a carb.
I'd use a Double Shaft Engine to Replace the Original, and use the Pulleys that were on the Original Engine. GL.
I was thinking about swapping the double shaft tecumseh parts onto the single as I have just learned is doable. Still thinking of trying to run both of the single shaft. I also thought the HS40 is complete and someone would like to make use of it.
