hey gang, Bought this a couple weeks ago and it looks like someone has been in it before. I don't believe the throttle/ gov linkage is all there.
I did get this running. the intake valve retainer was broke in half. but I only found the one half. guessing someone pulled it out. I think it would be too large to fall into the sump.
so $35 for thrower and $2.14 for the retainer and she runs. all gears work as well as auger and diff lock. cleaned up well.
is there a thread on here with proper linkage installation like pictured?
Discussion Starter #2
oh yeah. note to self. watch how deep the threads are on your compression gauge. mine made contact with the valve. glad I used the pull start.
also, here is a pic of the broken keeper I found.
I have this thing running pretty good right now. but my WOT is too high. still questioning the Gov linkage. anyone have pix of theirs for reference? Tecumseh 8hp
Does it have a small torx screw on the throttle lever, with a spring under it? I can't see if it does on any of you pictures. On new Tecumseh's they do, and its the high speed adjustment.
you should have 2 wire rods connected to the gov arm. pics of throttle lever and throttle linkage would help.
i just installed a carb on my 10hp tec, should be similar to yours, vid will show the linkages(2 rods) , 1 from throttle lever to gov arm and 2nd from gov arm to throttle plate. installing a digital tach will confirm if rpm is too high, should be max ~3600rpm
digital tach install
Hello LONG, that spring you have in the first picture is for the engine mounted throttle control lever, as seen in the attached video.
