2007 Ariens 926LE w/Honda GX390, 1988 MTD 5/24 Sno-Trac w/Tec 9hp, Kubota 2230 w/Kubota front mount
Hello All,
I have gathered info from useful posts on this site for years and finally have a question that I can’t get to the bottom of.
I have a modified 2007(8?) Ariens 926LE, AKA 926001 model that I do a substantial amount of area with. We are blowing appx 350’x18’ of farm driveway and roundabout in an that has a ton of snowfall and drifting. Up here, Honda blowers are the clear favorite but we could not afford even a used one amid supply issues this winter.
Bought the 926LE used, in some desperation, after reading a post here indicating that the chassis, sheet metal, impeller diameter, controls, etc are the same as the Pro and Platnium models.
Immediately witnessed the belt slippage and need for more power, so acquired a low hour Honda GX390 ($180) and installed Ariens double belt kit (a fantastic deal for $60 shipped!). The pulley says SHO/PRO right on it, so I assume it is the same as the more powerful models.
Performance afterward was FANTASTIC, with the machine shooting snow a great deal further, and able to clear lighter snowfalls in high gear. For 6 days that is, until the auger gear case gears stripped...
The new gears are $130+ various seals and washers, and past experience inside MTD gear cases says to just buy the whole new assembly. The direct replacement aluminum is about $300 with shafts and the cast iron replacement for the Pro/Platinum is almost the same.
Can anyone tell me whether the fan/input shafts are the same between the aluminum gear case and cast iron gear case models? Ariens has not been helpful, or I haven’t gotten the right person on the phone. AFAIK they have the same impeller and auger blades so it would stand to reason that it could be a direct swap.
Or, could somebody with a newer Pro/Platinum please measure their input shaft diameter and exposed length?
Thanks for any help!
PS, the 9 horsepower Tecumseh went on a freebie 5/24 MTD tracked rig, with a 1/2” increase in impeller drive pulley diameter. Really turned the thing into a little monster. The small impeller doesn’t throw nearly as far as the Ariens but the track system has clear superiority in deep snow and, interestingly, with less operator input and fatigue.
