Hi Guys
I'm a new guy here and have a question you can help me with. I just was going over my model 932027 7 hp blower and found the plastic wheels have opened up on the axles. There is a lot of play in the wheels once the blower is lifted up. Are there better wheels available to fit this model maybe steel? These are not keyed but just have a bolt through them.
Thanks
Gary
Head over to Scot's site;
and find your parts manual, should be early 90's. Then plug the part number into the Arien's parts radar and it will let you know the modern number (if its been changed). Then plug that number into any of the small engine repair shop websites and you should find what you're after. I've used Jack's with good results.
Thanks guys. I called my local dealer and they gave me the new part# but they didn't know if the wheels were steel or composite. I thought about removing the tires and setting up the wheels in my lathe to bore then sleeve them but it's not worth all that. For now I'll bolt them back on and use them.
