Anyone have any resources or video on how to do this? I have the new friction disk and started taking it apart. Baiscally what I have done so far is:
Serivce position. Took off bottom cover. Removed the three bolts on both sides that hold the bearing. Removed the two cotter pins on the shaft. I can't get the shaft to slide so I can get the friction disk assembly off. Do the bearings come off the shaft? Mine seem to be stuck on. I believe the bearings are what is not allowing me to move the shaft and get the disk off.
Any help appreciated. Thanks
The bearings do in fact come off. Needed some oil a persuasion. Now its just a matter of putting it all back together.
When I got the shaft out and the friction wheel assembly off two little parts fell off. A small bracket and a washer. #46 and #60 on this parts diagram. ----> https://ibb.co/c1VtjG
Anyone know where the washer goes?
It goes on the inside of the selector shaft U shaped retainer.
