1 - 20 of 27 Posts
Trying to get my brother in laws snow blower started...it’s an Ariens Deluxe 28 model 921037 with an AX 414 engine...from what I understand it’s been sitting for about 3 years...It had a full tank of fuel so I drained it through the carb bowl to verify I had steady fuel flow...then I put fresh fuel in with seafoam...there is no fuel filter other than the screen in the tank opening...then I pulled the spark plug and cleaned it and reattached the wire and grounded the end of the plug against the engine and pulled the cord to verify I had spark...then I pulled the carb off and ultrasonic cleaned it...reassembled everything and tried to start it with the electric start and the gas cap loose in case it was a vacuum issue and it was backfiring but will not start...any ideas?...thanks in advance
I have the same machine same motor
Look at the 2 wires near the carb bowl makes sure they are not grounding out there is tsb about this i really had to dig to find it
http://apache.ariens.com/manuals/B-2116.pdf
that is a killer machine when its running right
fire your bil for letting it sit 3 years
Thanks a ton...I think my dad said he was seeing a spark from inside the shield when we were trying to get it started...this may be the issue...does it matter which wire is on top and which is on the bottom when switching to the opposite side?...also just wondering why swapping sides on the run/stop switch would fix the issue?
the wires are routed very tight bad design
just check them for int grounding
see if you routed them back the right way 1 should almost be above the carb
Thanks again...so I should be trying to separate the routing of these 2 wires?
As best you can you dont want them taught so there is pressure on them when the machine is running/ vibrates
Is that white covering still on the wires ?
make sure those are protecting the wires
Sparks and gas are a bad combo
The moron i got my machine from had pulled the bowl as he left gas in it
Had the wires in a bad place and the white covering was not in the right place
I had some int grounding and stalling
I re routed 1 wire above the carb and moved the white covering back where it should have been
No more sparks no more stalling
Its amazing what a bad owner can do to almost brand new machine lol
So I started to follow the TSB and decided to swap the spark plug from my platinum 30 sho (same engine) and give it a try and it fired right up...now it will start and run but the engine surges and backfires and it dies after a few minutes when the choke is off
For my curiosity, you re-routed the wires, or you changed the spark plug? Or both?
If it's surging, but smooths out with choke, then you are running lean, and your carb is likely still dirty. It's possible the jet is simply the wrong size, and is forcing it to run a little lean, even if it's perfectly clean. But a little bit of dirt somewhere is maybe more likely.
If you know the carb is fully clean, you *could* try opening up the jet a little bit. But I'd want to know that I could buy another replacement stock jet first, before I made any permanent modifications.
Clean the carb, what you do depends on your knowledge, adventuresome, and how dirty the carb is, a spray carb cleaner, carb dunk tank, ultrasonic cleaner.
I took off the bowl and took out the jet and imulsion tube and sprayed carb cleaner up the shaft it sits in Pay attention to how the tube comes out
cleaned the jet and all the tiny holes in the tube and it solved the issues you speak of run 2 or 3 tanks through it with seafoam you should be good
Pay attention to where the drain plug is before you remove the bowl it needs to be there to no hit the float
whole thing took me 25 min
you can get it out with a flat blade screw driver just be carefull
I would try that before removing the carb its quite abit more work to get the carb off on this blower
not like and old flat head tech or ohv tech you can do in 5 min
the carb cost a fair amount as they have idle down i think the cheapest is 75 bucks
good luck
I already ultrasonic cleaned it...see my first post
good luck
Thanks...I guess I’ll pull the jet and give that a shot...I could see daylight straight through the jet when I removed it to run it through my ultrasonic cleaner...not sure if there are side holes as the jet didn’t seem to extend too far into the carb air passage
Thanks...Did not reroute wires...both wires had the white sheath on them and there was a white sheath that housed both wires together....just swapped plugs and then bought a new plug and replaced it...think I’ll pull the carb again and pull the jet and the float and needle valve...not my first rodeo with carburetors but I wonder if I need a rebuild kit and one of the rubbers isn’t sealing properly and letting in air...but I’m not seeing any fuel leaking either...probably won’t be opening up any holes in the jet
1. Surging can happen because of a plugged fuel screen and or a collapsed fuel line.
2. The float could be stuck and or filled with fuel and heavy in the float bowl as this snow mule has been sitting idle for three years with no care and no amount of cleaning will help that. I have been there and done that.
You also have to plan on changing the fuel hose rubber line and adding a shut off valve as well as the old fuel tubing will collapse if it is weakened from age and it will rot.
The good woven fuel tubing is worth every penny.
I would change the fuel tubing and set the gap on the new plug at 25 thousandths and let it run for a while at half throttle to see how well it runs.
The newer engines have to comply with the EPA regs for exhaust pollutants now and they are essentially detuned and the way to get around that is to install bigger jets BUT I would regap the plug and dumped out the fuel tank and changed the fuel tubing with good woven fuel tubing before I changed the jet though.
Changing the jet is the best option with poor performance of a snow mule with a good engine in deep or heavy wet snow pack that has melted and frozen over night hence the existence of the END OF DRIVEWAY MONSTER.
Thanks...Fuel screen is fine, fuel hose was tested by disconnecting from carb and letting run to ensure uniform flow, carb is clean via ultrasonic cleaner, float has no holes, float isn’t stuck, oem fuel shutoff works just fine, brand new plug was factory gapped equal to the old plug
how bad was carb, gas left in for prolonged period?
just because u cleaned it via ultrasonic doesnt mean it was successful. use carb cleaner, brass wire brush and small diameter wire to clean it manually, make sure all holes are cleaned thoroughly and reassembled correctly especially float and needle and main jet(s).
i cleaned my carb 3 times before i was satisfied.....and i still bought a cloned one to compare performance, clone ran better.
any bad air intake gaskets, use carb cleaner to test w/motor running.
its most def running lean.
unlikely but possible, valves
I've cleaned carbs in a ultrasonic cleaner and still have had problems with them. After I disassemble the carb, I spray carb cleaner in the holes to soften any debris and to see if any holes are clogged prior to the ultrasonic cleaning. I always use a welding torch tip cleaner for every hole. After the ultrasonic cleaner, I use the carb cleaner again. And if it still doesn't run right, I remove the Welch plug that goes in to the throttle body, if from the beginning I feel the carb is going to be a problem, I remove the Welch plug prior to the ultrasonic cleaning. And even after this, there's times I've resorted to a Chinese clone because it ran better or started easier.
I've had good luck so far with just the ultrasonic cleaner. But it can't fix everything.
It will dissolve varnish, etc. But it won't disintegrate a little piece of rubber that came off a fuel line, or a grain of sand, or rust, and so on, if they got stuck somewhere important.
So I think also mechanically cleaning the passages still has its place, especially if a problem persists.
Discussion Starter #18
Pulled the carb again...when I removed the fuel line I ran it into a bottle to ensure good fuel flow (have a video of it running into the bottle)...removed the bowl, removed the float and inspected for holes, no fuel inside and no holes...float is plastic...needle valve was fine...pulled the jet and inspected...I could see daylight through every hole...since the holes continue all the way across...no evidence of any rubber chunks from fuel lines...but I soaked the jet and needle valve in carb cleaner anyway...blew them out with carb cleaner and air...reassembled everything and I’m right back where I started...still surging (have a video of that also)...any other ideas?
Two things, have you pulled the low speed jet, It’s actually a plastic plug held in with the throttle stop screw on the top of the carb and I know you pulled out the main jet but did you also take the emulsion tube out, It’s a brass tube with pin holes that is held in by the main jet, You may have to push it down from the main opening behind the choke flap with a small screw driver but if that is also blocked you will not get it running too well.
Reactions: Point37
Discussion Starter #20 (Edited)
Pulled the emulsion tube but did not pull the low speed jet...could that cause a surging condition?
1 - 20 of 27 Posts
