The only efi I have actually troubleshooted and repaired myself with a garage tools a multimeter and a service manual was a Kohler command 741.
Kohler was simple fuel pump, injectors, crank sensor, temp sensor, baron sensor, throttle position sensor. It still used the mechanical govenor though to work the butterfly which made it Very simple. To me it seemed Kohler didn’t redesign system from scratch but used available gm Delphi parts from old 3100 v6 like Harley did on some years of their injected bikes. Proven technology and cheaper aftermarket parts at auto parts store. TPS was worn out in one spot and could measure this with a multimeter. Removed it saw that it was Delphi Went on computer found Delphi tps on Amazon for less than $20 bucks. Kohler was $80.
Haven’t seen ariens efi. But from description of tps at throttle I assume it has a servo motor on the butterfly. My guess would be older Asian auto technology since motor is LC branded ariens
Can’t imagine fresh proprietary efi but might be wrong.
I think efi will be the norm as emmession get tougher. I see the point of others as dealer only repair $$$. Here is the thing. The only difference between dealer and self diagnosing in your garage is knowledge, tools , and procedure. We are all men. We just need to learn how. If tech manuals information is available garage repairs can be done. Knowing how to measure millivolts ohms and milliamperes and fuel pressure is the way to troubleshoot efi.
We live in a disposable world and right now efi is an option not the only option. If it is something you don’t think your capable of troubleshooting don’t get one. If you get efi and it breaks there will always be the harbor freight engine replacement option and it might even be efi in the future for $ . Imagine a 200$ efi engine complete. Efi is newer tech an $$$$. 60 inch TVs used to be 4000$. Now they are $700
The one thing about the ariens efi that I don’t like or unsubscribes understand is the 8vdc battery. Not a commodity item for replacement available at auto parts store. My 2 cents
Shawn
Shawn
