The spec's for the LCT engines specify 3,850 +/- 50 rpm as the governed engine speed. Ariens use the LCT engine but spec it as 3,600 +/- 100 rpm. I have a 2015 model year 414cc AX engine that ran at 3,450 rpm when new so I bumped the governor up to 3,700 rpm in the first year. Subsequently to 3,900 rpm for the last several years. Those measurements were with a laser tach. For this season I added a Runleader hour/tach that also shows 3,900 rpm and how the rpm drops under load. Attached is a pic.Anybody with any other size engine, 208cc and up, that suppose to run at 3850 + - 50 rpms at no load, have a tach to verify that it does??...Just irks me why the 254cc is set lower at 3600......Never got a answer back from LCT...
Well looks like yours was set at 3600 org. but the spec. is 3850..,so we will never know the real story behind this..Did you notice any difference from the org. setting to what you increased it to?...The spec's for the LCT engines specify 3,850 +/- 50 rpm as the governed engine speed. Ariens use the LCT engine but spec it as 3,600 +/- 100 rpm. I have a 2015 model year 414cc AX engine that ran at 3,450 rpm when new so I bumped the governor up to 3,700 rpm in the first year. Subsequently to 3,900 rpm for the last several years. Those measurements were with a laser tach. For this season I added a Runleader hour/tach that also shows 3,900 rpm and how the rpm drops under load. Attached is a pic. View attachment 176380
The machine has just over 50 hours on it this season so far, but the snow is half the normal amount this season.
Yes, I was disappointed with the performance at 3,450 rpm, it felt weak. Increased the rpm to 3,700 and there was a profound improvement in snow throwing. Increased the crank mounted impeller pulley from 2.75" to 3.25" and the rpm from 3,700 to 3,900 rpm and still an improvement. Neighbours noticed that my machine threw the snow father. It has been several years running like that so probably 150 engine hours.Well looks like yours was set at 3600 org. but the spec. is 3850..,so we will never know the real story behind this..Did you notice any difference from the org. setting to what you increased it to?...
Well sounds like yours worked out with no problem..I will see , since mine continues to get more stronger with each run...counting a one more Big Daddy, would be a good test..Yes, I was disappointed with the performance at 3,450 rpm, it felt weak. Increased the rpm to 3,700 and there was a profound improvement in snow throwing. Increased the crank mounted impeller pulley from 2.75" to 3.25" and the rpm from 3,700 to 3,900 rpm and still an improvement. Neighbours noticed that my machine threw the snow father. It has been several years running like that so probably 150 engine hours.
The engine sounds much better at 3,900 rpm than at lower rpm. We are only talking about a 300 rpm increase over the Ariens AX spec of 3,600 rpm. So an 8% increase, not exactly crazy fast.
