Stop ignoring the valves!!! See post #18. This is an easy diagnostic step to perform. Just 4 bolts to remove the valve cover.getting so desperate now I plan...
Get some kroil or PB Blaster and a rubber mallet. Get a little penetrating oil on the shaft. Wait a while as it needs to creep in. Apply the puller. When you have some sack on it, whack the shaft hard with the mallet. Should pop off.I have the Compact 24 model that will not start. All the usual suspects have been cleared. It appears I have a sheared Woodruf key and need to remove the flywheel. Any tips? I may have access to a gear puller tomorrow. It seems like one whole unit. ie one piece including the gear? The thing will not budge and fear hitting it too hard. I'm thinking the puller will grip behind the gear and I can pull it off. Wondering if this makes sense..
