Hey I recently purchased a ariens 24” snowblower and I’m new to this forum. I would like to install an led light on it. It does not have a headlight. Can this be done?
Depending on if the there is any power in the engine, I have added a new flywheel and stator to add power but I needed a new flywheel anyway as the old one got damaged so spent a little extra for one with a stator, If the engine has no stator or power you may want to try a battery powered light as many on here have done with good results as a stator can get expensive if you don't find a good deal.
AH it has a LCT engine same as mine, Mine is from a Ariens Sno-Tek so same engine. Yes you can add a LED light as I did also. There is a thread here some place on the parts needed and all the info you will need to do it. I'll see if I can find the thread.
Here is a thread that someone goes through what is needed and how to wire it so the LED works correctly.
