Long post, AGAIN.....apologies gents
So I think, and as eluded to earlier this Molex connector (see included picture below) is flaky.............I've verified that since the stator provides the ECU its AC signal (for tach, battery charge source, etc), the ECU(its PCB components) then is/are also conditioning (rectify, filter and regulate) this AC stator signal that it sends as DC back out to charge the NiMh battery.
Yes.....Once the machine starts, you can unplug the NiMh and she continues to run like a top as the stator(magneto) now obviously can provide the ECU its necessary power(and AC freq for tach etc) to run things........I've just ran mine this way.
Sooooooo, the point here? If the battery connector is flaky as mine seems to be, the battery got me started and yet was not properly charging once running (vibration in the dash is perhaps making the connector flake out). i.e., Each time it started, it took the battery down just a bit, BUT this also meant it was slowly getting weaker and weaker a little bit each time because it's not really getting charged back up while running until POOF!!!!..........Insane ops of over priming and
gas leaking out onto the tire, starting but shortly after dying AND error code "27", low fuel pressure!!!
This is my theory and I'm sticking to it because I'm not sure I've quite starting doing my own stunts yet by leaving ignition keys on by accident.....LOL. But, the net effect s/would have a similar outcome........
Seriously though, the connector is flaky (shitty pin engagement) while plugged and locked together because if I wiggle it about AND with the key on(but not running), the ECU's power cycles on and off telling me it has a flaky connection........ALSO the wall charger "charging" indicator light flips around from green to red if i wiggle the connector.
I can only assume it's doing the same while plugged into the ECU and running..I'll be replacing this connector with a bit more positive engagement connector. Perhaps I just got the only bad one, BUT...........
I've already tore into this thing down to the stator and back out just because that's what I do, it's a sickness I have......... HOWEVER, IMHO it's still a simple and well designed machine. The exception (as I have found and I'm not a snow blower design engineer) as stated above, is the Molex connector (and a firmware update, see insanity ops above) they've used that connects the ECU's output to the battery.
The stator, bridge rectifier, injector, pump and all associated connectors/wiring including the fuse box, sensor interconnects and electric chute/deflector hardware all seem very solid and of high quality components IMH[O] Opinion/Observation........
I think I'll keep mine, anyone wants to sell theirs? I'll buy it!!!
