I am considering looking at a 2016 Platinum 30 that’s for sale for $700. Fair price? Anything to watch out for during inspection?
I think that's fair. I paid $650 for one a few months ago from a family that was moving. They had it serviced by the local Ariens dealer so it's ready for the fall and in fantastic cosmetic condition.
There's nothing special to look for, just use your eyes and ears to evaluate it. Check the scraper bar and skid shoes for wear. Make sure the augers aren't frozen to the shaft. Make sure it starts and runs smooth at idle and full throttle, test forward/reverse, auger and impeller, chute movement, electric starter, shear pins, etc. Obviously, check the oil and ask questions about maintenance and intervals.
Take a look at the seller's house, garage and cars. Is everything well cared for and reasonably tidy? If a prior owner doesn't give proper care to their home, you can bet the same is true for the snowblower.
I don't know about US prices. That Platinum 30 SHO has Autoturn which is a locking differential. It should turn very easily as though it were an open differential, but it makes a clickety noise which is normal. The system should drive in a straight line, but is sensitive to friction loads steering the machine to the side where friction is highest. The Ariens plastic skid shoes have virtually no friction and best suits the machine. The stock steel skid shoes have high friction and I don't like them at all, perhaps the extra bucket weight causes this sensitivity. Ariens suggests that the bucket should be aligned properly and have this video to help you:
https://www.snowblowerforum.com/forum/ariens-snowblowers/12298-ariens-auto-turn-adjustment.html
The engine should run at 3,600 rpm at full throttle, but can come from the factory (like mine) with less rpm which you will not like. It can be adjusted to spec. The engine starts well on first pull in the coldest weather. The rubber tired friction wheel wears in a couple of years but I use the machine a lot. On the left side of the chassis just in front of the wheel is a rectangular opening with a black plastic indicator. The indicator is a measure of wheel drive clutch adjustment. All the way forward for clutch released, as the clutch is applied the indicator moves to the rear of the slot. At middle is normal but at the back of the slot means rubber tire friction wheel is worn out and needs replacement.
There is a chute lock that should hold the chute in any desired position. It can get damaged if chute hits a ramp guard rail and will not lock. Easy to fix and adjust again. The chute deflector should point down and fully up out of path of snow so may need adjustment of cable or hinge points if movement is slow and not snappy.
It is an excellent machine, you will be happy with it.
Good luck.
That seems like a very reasonable price. This unit retails for about $1800.00 USD when new. This machine is powerful, will throw far and handle the plow pile with relative ease. A shortcoming is the LCT engine has a very small fuel tank for the 414cc engine, if you have a long driveway plan on refueling often. I would also check the fuel cap operation take it off and put it back on, it is a poor design bayonet style cap, that sometimes leaks. Good luck!
Good advice from Rod 330.
I'd also make sure it wasn't used professionally.
Good luck,
