1 - 3 of 3 Posts
Hi All. I just picked up an Ariens ST420 second hand. The model number is 932023, and the serial number is 008337. Other than downloading the owner's manual, I am unable to find much information regarding the motor. It is a 4hp Tecumseh, but I am unable to find a serial number on the motor. . The starter/recoil is also broken and does not turn the motor over, but the electric start works fine. I would like to get the starter recoil fixed and replace the belts. Does anyone know the part number for the starter/recoil? Thanks.
I’m thinking it’s the older style starter, Had a ST420 a while back but can’t remember, Anyhow EBay is the best resource for those Tecumseh parts and can be found pretty cheap also.
I think you may need this one (the older style)
https://www.ebay.com/itm/Pull-Recoil-Starter-Assembly-For-Tecumseh-Snowblower-Bike-590420A-590706-16575/291865402150?epid=1783280847&hash=item43f4889b26:g:tPcAAOSw~flcUWoj:sc:FedExPriorityOvernight!02745!US!-1
Do a search on eBay and find one that matched up if yours is a newer style.
Reactions: Deekster1980
That is great advice. I will check eBay out.
I can’t find much information on the engine. By any chance do you know the model of this 4hp Tecumseh engine? For the life of me I can’t find a serial number anywhere, unless wear and corrosion have deteriorated the numbers. I will check again later tonight after work.
1 - 3 of 3 Posts
