1 - 10 of 10 Posts
Just picked up a 10hp snow king tecumseh single shaft to put on my st824 924050
I only need new drive belt and a bigger auger pulley likely a 3 1/4 or 3.5'' od .
It will be a cool project to make my machine hopefully throw a bit further and eat up snow banks faster. i will post pictures..
Camouflage Light Product Military camouflage Sleeve
New engine
Snow Tire Wheel Automotive tire Motor vehicle
The machine that i had restored 3 years ago
i hate to be a bit of a downer and hope it works good for you but that personally wouldn't have been a engine that i would have considered for a swap. if it works it will likely be fine but my biggest concern would be parts availability if you ever need them since that style engine was only built for a few years before they were discontinued. i would have probably shopped for a newer style engine like a powermore or some sort of honda knock off that parts are more readily available for.
Everything depends on price, immediacy, and necessity
Discussion Starter · #4 ·
i get the point but at the same time these engines are so cheap if anything top end breaks i doubt it will be worth fixing.
and i have a few parts still.
i would have definitely liked too put a gx390 on it but that is too expensive for now
so going from 8hp to 12hp, going from L-head to OHV. Should be quite the upgrade, more powerful, smoother and quieter.
Reactions: Julien Morrissette
Julian, If you do want to go bigger sheave you may need more belt cover clearance. On some of the 924 series they used belt cover risers (you may need if your crank is higher on this 12hp OHV). Just FYI look up 924092 to see parts numbers, but you can make them (15 and 17 here)
Automotive exterior Font Line Triangle Parallel
Discussion Starter · #8 ·
wow i didn't know that. Than you i will probably make them myself !
1 - 10 of 10 Posts
