I have found this snowblower on a classified ad. The snow blower looks like a brute but as always. I can't find reviews, how old it is, or if Ariens makes parts for it yet. I will be using this for my small business, servicing clients during the winter. I like Ariens equipment but would like some input on it. Seller didn't post the model number and looks to be an older model. Any input is helpful and if anybody has had this model, how well did it work? MODEL# 924050
Thanks
I peaked at the manuals and that model number looks like it is probably from the 80s or maybe early 90s. Ariens is really good with parts, plus there are a lot of old blowers for sale that you can use for parts. They tend to use the same parts for almost all of there blowers so bearings and other wear items are still the same ones they were using back in the 60s. Make sure the front gearbox is good and it rotates smoothly with no dead spots or noises. Also give both front rakes a wiggle to make sure they are not rust locked on the shaft. If they are rusted that means the gears will break before the shear bolts if you hit something. I find the best way to check is to grab one side and force it tight in one direction then try to rock the other side back and forth and you should see a little movement. If you have some up and down play in the auger shaft or the wheels it is probably just the bearings / bushings on the ends and those are generally pretty easy to replace.
924050 is a long-lived model that was produced through most (or all) of the 1980's..
So its 20 to 30 years old..
but dont let the age bother you! ;)
if the machine is in good condition, the age isnt a major factor..
(if you can also post the serial number, we might be able to work out the year with more certainty)
Info on the 924000 series in general:
And some manuals:
http://apache.ariens.com/manuals/24449B.pdf
http://apache.ariens.com/manuals/PM-24-80.pdf
http://apache.ariens.com/manuals/000123A.pdf
If its in good shape, it should be a fine machine for your business!
