cant get thrower to start,
, its getting gas, plug gets wet, its like the older mtd single stage,
has that oblong flat key,1 wire goes from the coil to the key slot, the other goes from oppside of key slot to a ground on the motor,
should i just bypass tha with a toggle switch, 1 leg to coil 1 to ground?
i was also thinking of the 'baking'trick for the coil, i have another one, its not very possible both are shot
