Hi all
3x26 (non-HD 2013)
I broke a shear pin in the back accelerator. It appears that the flange bushing is covering the pin hole. There are 2 bushings, or there should be based upon the schematics. I moved the auger back and forth and it seems that the bushing stays with the auger. It was cold out and I got bored of playing around. I will wait for a warmer day to tackle this problem. But I do have a question:
Should the 2 bushings leave a gap in the middle where the pin should be? If so I'm guessing that the flange on the bushing wore off and the bushing slipped inside. If there should be a gap between the 2 bushings I'm guessing that I will need to take it apart and replace the bushing. Seems like a lot of trouble to replace a piece of plastic.
thank you
You made me wonder if they upgraded this part...
I looked at the latest version and there is a new part number and the back bushing seems to be integrated. But the photo of the part just shows what looks like the same bushing installed, instead of a separate part... maybe the upgrade was some glue :)
Yup, it was the flange, or lack of one that caused the problem. The bushing in the back of the rear accelerator/auger was missing the flange and that allowed the bushing to slip inward and cover the hole for the shear pin.
So, if anyone is having a issue trying to find the shear pin hole on recent MTD built snowblowers this maybe the problem. Most seem to share the same part 741-0493C. It's the third revise since the 741-0493A - not sure what the upgrade was?
Here's a link to a nice (easy) video on how to remove the auger assembly, this is for a 2x version but it was the same for the 3x model.
photos showing the missing flange below.
.I Prefer the Traditional Style Augers. Will be interested to see if they Continue with this style.
