In the past, Ariens had full length gearcase shaft to support the augers. Now they use gearcase supported with a bracket to the casing with small shaft attached to the augers, The augers now have bushings with plastic inserts at their ends which can't be greased like the old bushings with zerks on augers near them..
Did Ariens made that for cutting costs or the new way to attach the gearcase to the casing is better than it was with full auger shaft length ?
My guess is it's cheaper to manufacture. One good thing is you won't have rusted frozen augers to the shaft from not greasing it properly.
Reactions: RedOctobyr
Areins got cheap with everything over the years, as did everyone else. They want them to wear out so they can sell you a new machine every couple of years. Nothing is built to last anymore like it was 30 to 40 years ago.
My thoughts as well, on both points. All things equal, I'd rather have a full-length auger shaft. But at least this way you're less likely to end up with augers rusted in place.
Another cost-related benefit to Ariens is that they can likely produce just a single auger shaft, whether used on a 24", or a 32". Fewer parts to manage, etc.
I would have thought the Ariens 1024 Pro model would be a full length auger drive shaft that did not need a gearbox support.
The Ariens Platinum and down models use the short auger shafts and use a gearbox support to the top center of the bucket to prevent unwanted movement. The Pro models 926xxx use the full length auger drive shaft and do not need the gearbox support. So full length auger shafts are still in use by Ariens. The Pro models use a larger diameter auger for more snow throughput and the gearbox support would not help that and may get in the way since Ariens use a very wide and complex support structure.
I think most machines use the short auger shafts, like Honda and Murray and Simplicity and Snapper and John Deere. The short and long shaft models seem to standup fairly well to most conditions. Neglect is difficult to accommodate. It seems cost is not such a factor to Ariens than building the strongest and best performing Auger system for their top of the line machines.
Mine does have a full-length shaft, if that's what you mean. I may have phrased my post poorly. I meant that I'd rather have full-length, but that at least I can see some benefit for the user with a stubby-shaft machine. For the person who never greases their augers, they might be more likely to stay free on the shaft, and not blow a gearbox due to rusting in-place, and then hitting something solid.
My machine is a 924-series.
If you want my thoughts, using a stub shaft off the auger gear case is a bean counter decision. If you have a full length shaft, you have X number of configurations - 1 for every width of auger housing. Now if you use a stub shaft and a bearing or bushing on the external end of the auger rakes, you have 1 configuration to use on every width of auger housing. That leaves you with less inventory overall because you're using the same setup in every machine regardless of auger width.
I have had a couple of machines come in where the rake had come off the bearing (don't ask me how as I'm not sure) and the rake was banging on the housing because of it. Had to disassemble the auger housing to get the rake back centered on the bearing. Looks like the end panel of the auger housing was pushed out which caused the issue.
Understand, I've come up against machines like this before and I'd rather have a full width auger shaft regardless of width. They are stronger IMO and will have less problems over time as long as you maintain them so the rakes don't rust to the shaft. I've wondered about finding either a full with shaft to replace these stubs or have a shaft made as it shouldn't be too expensive. big thing would be if you can configure bearings or bushings on the outside of the housing instead of those things they're using.
My 2 cents.
