Hi i have a new-to-me husqvarna 1130sb-ls. There was a little bit of up and down play on one side of the auger shaft so I ended up replacing both side bearings. However there is still the same amount of play. I was wondering if this is normal? My old blower had bushings so the auger shaft sat tight in the bushing and has a lot less play. There is a decent amount of space between the auger shaft and the plastic bearing retainer on the inside but i wasn't sure if this was normal since it has a bearing and not a bushing. Here's a picture of my manual, the bearing that comes in front outside the auger housing is what I replaced. And a picture of the inside of the housing that you can see the bearing retainer/auger shaft.
