1 - 20 of 25 Posts
I'm looking at an impeller kit project where the flap will be projecting close to 1/2". The common baler belt I see like at Tractor Supply seems like it will get folded back quite a bit.
Have there been any good experiences with other materials like UHMW or urethane?
Thanks,
Pete
I dunno, Pete. I think UHMW or HDPE or anything like that is maybe too hard. Why not try backing about half the distance with light steel plate? It'd still be rigid but would have some forgivness in it as well.
I saw a guy on another forum use a cheap cutting board. The white kind that are made of Polypropylene or Nylon Plastic. It worked out pretty good.
Hah! That's what I make my blower skids from.
Thanks,
Pete
Hi Pete
Sandwich a metal bracket on each side of the baler belt extension which extends out past the impeller to take up some of the distance. The metal bracket will support the belt and keep it from bending over
We had a 2 inch snowfall the other day and the snow plow pushed up 6 inches along the end of the driveway. I went out with the MTD tonight and it tossed the snow 40 to 50 feet. I threw it towards the power lines and it seem to almost touch them. This is what a tight impeller kit will do.
If I recall correctly one used truck flaps and or cheap tire sides but I may be corrected for making SS flaps out of them.
sixtyfiveford on youtube made ss paddles out of sidewalls. I think he may be a member here.
I've got some used toro s-620 paddles which are much thicker than the rubber pieces that comes with the Clarence kit, you might want to look for some used s-200 / 620 paddles
I agree, you could not let that stuff ride on the inner impeller housing like the rubber flap kits do. there's a guy on youtube that had a video up of a harder type flap kit, my gosh that thing made so much noise it sounded like an engine that was ready to toss a rod through the block. way too noisy.
you may want to try a tractor/truck supply store and buy thick mudflaps and cut them.
the key isn't the material, it's the backing plate. that's why the Ebay impeller kits with the steel plates/hardware are in reality, a deal. you don't have to go find and buy all that stuff, or cut your own backing plates.
my challenge isn't throwing distance, it's the fact that this year, there's been very little snow, and what we do get is crap wet snow that melts in a day, and the ground is not frozen so blowing snow becomes an exercise in futility, if not stupidity- unless you have a concrete or paved driveway.
but there's something about a paved driveway that feels like living in a guilded cage. I like natural surroundings, including dirt roads.
First off, thanks for all of the input so far.
As background I'm looking at something that will need to go into small scale production, not a one of a kind arts and crafts project. I've done one that way. Now I'm trying to go from something that worked to the best thing that will work because I'll be spending real money. All that being said I need to stay with a commercial material that can go on a water jet, punch pres or laser cutter.
An actual blade extension, clamping plate and hardware seem to be givens. A metal backer to help stiffen the flap would be an extra cost item #4 that I'd like to avoid.
In my limited experience the Clarence type kits may rub initially but soon burnish in and run with a slight clearance. Is that the common thing for you folks? My design intent is to have the kit install with a slight airgap but for the sake of deflection and so forth want to stay non-metalic so it doesn't become a spark shooter.
Please keep the ideas coming!
Thanks,
Pete
I don't see many options Pete, other than some type of belting material or other rubber based product. As greatwhitebuffalo pointed out, anything hard is going to sound horrible. Also in cold temps I'd figger that solid materials such as HDPE are going to get a little more brittle? If you're going for a good, quality small production, people will or should be willing to pay for that quality. I still say steel backed/belting is the way to go.
Wishing you all the very best in your venture.
Like buzzard mentioned, the old school s200,620 flapper blades do a great job(need a punch to make way for bolts, but pretty straight forward). My buddy is a master at welding and he thinks he can just add a bead of weld and grind it smooth. Measurements and complete removal of the system are required, but most of us do that anyway. Every time I weld, I burn holes in stuff I'm wearing and near the bench:rolleyes:
Hello Pete. I am not familiar with bailer belt, but I have worked with conveyor belt material. It is always a corded material which will hold up to extreme wear the same as most single stage snow blower paddles. I found this company and I'm sure there are many others.
Used Conveyor Belting | Repurposed Materials- Repurposed Materials
They have some 1/4" x 28 1/2" x 12' ($45) listed under the Chicago warehouse section. Just something for your consideration.
I just picked up some old grain conveyor belt(about 2'x1') from the girlfriends family farm. It seems stiff enough to hold yet bend if it needs to. Now I just need some snow to test it on.
A friend was changing the rubber blade on his Toro single stage. I cut the rubber, and let it rub fairly hard against the barrel. I sprayed silicone to help it break in. I used POR15 to coat the impeller blades. Great improvement for two years! Next year I'll use POR15 epoxy to coat the inside of the barrel for a smoother finish.
1 - 20 of 25 Posts
