i have an old mtd blower thats all wired for a light... my question is, can i just go to napa and buy a 8$ replacement light, nothing special? i thought somewhere i read it had to be a certain wattage...i had an old foglight i was thinking of wiring up to it, but i dont wanna have dimming issues..its an 8hp tecumseh hsmk80...
Look for something in the 18W range. LED lighting can be adapted with additional parts (rectifier diodes etc) but you may see flickering.
Toro Power Max
My Toro which has a 11.5hp B&S engine, came with a halogen 16W GE892 bulb. Don't know if this is too little, too big or what, just letting you know what I have.
I put a light on my ST824, using the flywheel and alternator from the 8hp MTD I had at the time. There was a certain bulb designation number that was a common one for these engines, as I recall (it was several years ago). If I wrote it down, I'll try to check what that was. I've sold the machine, so I can't just check it. But yes, something 12V, under 18W would typically be what you want, to avoid over-taxing the alternator.
Checked my notes. I bought an Optronics TL-10CSW utility light assembly at Walmart for $12:
Utility/Flood Light - Walmart.com
It came with a 36W PAR36 4411 bulb, which is too much for my 18W alternator. So I bought an 18W PAR36 4414 bulb to replace it.
At the time, I posted a bunch of info about my conversion process, including about the light, here:
How hard to remove Tecumseh flywheels?
The light's rubber housing for the bulb was quite stiff, I was having a hard time removing the original bulb from the housing. In the thread I described how I gently warmed the housing, to soften it, and was then able to easily remove the original bulb, so I could swap it to a lower-wattage bulb.
Good tip about the 4414 bulb. I was using a similar utility light with a 36-watt bulb on my Bolens 824 because its engine has the 84-watt stator, but now I know I can use it on other engines with the 18 watts stators after the bulb swap.
