The plow leaves a mess at the end of my driveway everytime it snows. :banghead: Wet, hardpacked gravel filled snow the worst. Very hard on my Honda. Thinking old school single stage type unit. neighbour had one and it appeared to do the job. A tough old single stage unit. I had an old Craftsman track unit that worked until it wore out. The Honda is too expensive to put through that abuse. All thoughts appreciated. Not getting a 4 wheeler with plow. Thanks.
grab an older ariens 10000 series unit, best thing i can think of that will hold up although you may want to upgrade the tires. they will hold up through a ton of abuse
I'd try and get a single stage with a metal auger. With the gravel mixed in I'm thinking the single would have less of a chance of jamming on you. I'd be looking for one without the serrated augers as that would just be another place a rock could get stuck.
Or you could take the time to line the impeller housing and chute with plastic and add an impeller kit to make sure a chunk of gravel doesn't get lodged in there. I'd think that it jamming or tearing up the housing would be the main concern.
The most cost effective would be a shovel. :biggrin:
The plow leaves a mess at the end of my driveway everytime it snows. :banghead: Wet, hardpacked gravel filled snow.......
Heck,I'd be happy if the plow guy left only gravel for me,but this joker around here leaves rocks the size of my fist.All of my two-stage blowers can deal with gravel,no problem.
He won't use shoes on his plow and he doesn't have the bloody thing set up correctly-the plow is angled too far forward and it rips the rocks out of the road.
His plow bounces and bangs along, you'd think he'd get sick of listening to that.He also can't figure why the bulbs in his plow lights have to be replaced way too frequently as well as his his cutting edges.I tried explaining this to him but he's dumber than a box of bolts.
I use one of those big snow scoops to remove the snow and rocks along the edge of my property for the first few storms until the road freezes up and gets a good layer of snow pack on it.
I live across the street to a dead end street,and the snowplow will back down the dead end street,then he will push the snow down the dead end street and push it up on my front lawn..I've tried to catch him,but they usually do it before I'm up,or after I went to work...so in the spring I have to patch my lawn where he tore up the grass...i guess I'm going to call and complain to the DPW supervisor...
My experience with the plow drivers is... the best thing is the talk with them. I talked with our plow driver maybe about 5 plus years ago, if not longer. I asked him about a few things. He treats us EXCELLENT! I can not thank him enough on how he handles our street, at least our side... He is also our road patch man and leaf picker upper, so... he knows our street really well. It helps to be nice. Calling the city I think is pretty much worthless. Talk to the source.
Get up a little bit earlier that one time. Once you do it, it will take care of a lot of head ache down the road. Providing he is a nice guy.
