1 - 10 of 10 Posts
Picked this one up Cheap with a blown Motor this Morning. Was going to use an 11OHV, but decided to save that one for Later. PO had just replaced the Auger Gearbox. Engine swap now done, This Will clean up Nice.
Jack,just out of curiosity , about how much will this go for?
Our Honda dealer just started selling Ariens a couple years ago also. They do seem sturdier than than the Honda but I have no experience with them.
I check the market on similar machines before pricing it.
did you use a new or used motor?
Pulled a Good Used One off the Shelf
So how do you determine if a used motor is good enough, especially for reselling a unit? Do you do compression or leak-down tests? Or is it more judgement based on your knowledge/experience. Just curious. Thanks
I just start and listen to a motor when I pull it and then drain the tank and carb for storage. If it runs poorly, I either fix whats wrong, or use it for parts only.
My Shelf Engines are Usually Strong Take-Offs from Machines I don't want to fix for Whatever Reason. I'm not saving any more of the 7hp and lower L-heads.
Reactions: paulm12
1 - 10 of 10 Posts
