1 - 20 of 24 Posts
I own two Bob-caT snowthrowers.
A 5 hp and a 1971 model 1824 7hp
...always tempted to buy more.
Like my signature says, proud owner of three Bob-Cat blowers.
*wave* I posted the first thread here. Loved my Crary Bearcat but to be honest my new machine puts it to shame -- except for the shear pins, which I'm still getting used to! I was accustomed to ramming the Bearcat into whatever stopped it, but when I do that now I end up kneeling in the snow replacing a shear pin. I'm sure I'll adjust, but I sure do miss that auger clutch.
I'm here. Dragged beast into shop and see my reverse issue is probably just the threaded adjustment on linkage. Big snow coming so I'll see to t in the morning. GJ
Is repowering a Bobcat with a Tecumseh pretty straightforward? There's one near me with a blown B&S 5hp engine.
Depends, if the motor has a 6:1 gear reduction like most of the early Bob Cat machines then you need to find another engine with the gear reduction. The later models that had the 3 or 5 speed peerless transmissions can use a standard engine and can be repowered by pretty much any modern engine. My machine has the 3 speed and the Tecumseh on there was a drop in to repower.
Reactions: thestonecarver
DB130, are you still looking for a Bobcat motor? This guy below down in Colchester/Oakdale Connecticut has a 5HP Briggs on an old Jacobsen that perhaps could fit. It's the same type of Briggs engine that they put on the old Bobcats. He's asking $50....
Link: snow blower
Welcome!!!
Welcome Autumn and Thank You!
Discussion Starter #15
Lol
I've gor two Bob-caTs, a 5 and a 7 hp with electric start. I inherited the smaller one from my uncle, who bought it new. I've owned that one for nearly 22 years. The bigger one I picked up about a year ago
I'll never forget the time I needed to replace the impeller bearings on the 5/20 in about 2000 ... the Internet was still a little spotty on content, and I ended up calling Ransomes in Johnson Creek, Wis, in search of a parts distributor. They gave me a phone number in Massachusetts, IIRC. I called it and they directed me to a mower shop ... half a block from my uncle's old home.
When I got there and told the counterman what I wanted, he went into the back room, came back with a plastic bag and literally blew the dust off of it. He had three bearings left -- I bought all three.
Since that time I've discovered Triangle Bearing in Oshkosh has all the needed spherical bearings on the shelf.
Edit: Gee, I looked at one of my two prior posts, and it looks like I told this exact same story on this forum nearly two years ago. Well, at least I'm consistent.
I've had a early 70's 5/20 BobCat for I guess more than 20 something years I remember selling my Eska s/s and adding a few $'s to buy it. I've never really had any problems with it, just bought belts and serviced as recommended by Wisconsin Marine. This year I just finished making up a new auger drive shaft with the 8 tooth sprocket and when I got into the machine to get it ready for the season I saw that the OEM sprocket, shaft and chain were still good so I just added a small 3/8" hole in the top of the chain cover to make it easier for chain lubing and covered it with a pop in plastic plug. The one thing that I never really cared for was the OEM Briggs flat head engine. Specifically the no float carb. I could never get a smooth, reliable idle with it. So I got ambitious a couple of years ago and re-fitted the flat head with a new Briggs OHV engine, and a handle bar throttle control. The torque of the new motor, and the smoothness through the rpm range made the swap more than worth the effort. If there ever comes a time when I can't keep the BobCat running I have no clue what will replace it. With the heavy wet snow we get on Long Island all I see when the neighbors are cleaning up after a storm is machines that are clogged up and operators trying to clear them with sticks and shovel handles, while I buzz through plow berms and have to lower the shoot to keep the BobCat from throwing that wet snow across the road and onto a walk way.
Here is my 1981 Super Rare Bear Cat the 1028 model Biggest Bear cat made. I yet to know anyone who owns one.The 1028 But Me ! she runs and purrs like a Kitten. I just upgraded to LED Lights (love them) Enjoy the video .
1 - 20 of 24 Posts
