Is it worth trying to find a scraper blade to buy for my 77 4 hp bobcat or should I just make it myself?
If I make it myself any idea on the thickness and width? Mine has been ground down pretty good.
I just ended up making my own. Got a chunk of flat iron for $3 and did a little metal work.
I have a welder so instead of purchasing another edge, or going through having to drill holes in the "new" piece of steel, I just tack weld it on. I do take the old cutting edge off as it's easier and safer to weld it off the machine than on.
I don't put an edge on mine because as you use it, an edge will appear.
