Introducing my latest find...
BobCat T7-2-24-40955 B&S 170452 1251-01 73062811
It has been sitting idle in a garage for 10 years. Apparently it would run back then if you squirted Carb-Cleaner into the engine/carb but not otherwise.
No idea yet what I have and what works or what's broken. Will update as I find out. As always, carb clean and fuel line check will be first priority.
Model : BobCat T7-2-24-40955
Engine : Briggs & Stratton Model:170452 Type:1251-01 Code:73062811
Pictures Here:
https://goo.gl/photos/1EGBpzz2am51u21y8
Currently hunting for any manuals or docs that might exist
Found these sites so far..
The Gilson Snowblower Shop's Vintage Machine Showcase
Bobcat Models
Discussion Starter #2 (Edited)
Briggs & Stratton Manuals:
By searching their website using Model 170452 and Type 1251
Gives hits for 170452 1251-99
Not sure how that relates to my 170452 1251-01
Nevertheless... here they are:
Results
I have a bunch of stuff posted in my info thread.
Denver got 12 inches (plus) of heavy wet snow this past weekend. (April 16 & 17 2016) Some areas got a lot more than that.
It was a heavy wet air mass heading up from the Gulf that swung counterclockwise, headed towards the Rockies and then dumped rain or slush or wet snow for the whole of Saturday and Sunday.
Once I heard that was coming I ripped off the carburetor, cleaned it, changed the oil, changed the crispy fuel lines and put the BobCat back together again (for now without a shut-off valve or fuel filter). This was the first time I had ever run it.
I didn't have time to mess with it to try to tune things.. but it started right up so I took it for a ride.
The throwing capability of this "non-standard" water-wheel impeller is impressive.
As many folks will know, the impeller is very narrow and spins in the same direction as the augers (unlike most other machines where the augers and impeller spin at 90 degrees to each other).
This thing throws wet slush better than some machines throw powder!
I tried to take a video but my phone was playing up and after I had finished blowing, the video was unplayable. Pity.
Anyway.... this is just an update to say that the machine is now running and throwing like a champ. I am beginning to see why people who have BobCats really like them.
BTW: The machine is super heavy! Standing it on its auger bucket takes a lot of strength just to get it up off the ground... so that means that the engine has a lot of work to do just moving the machine around.... that's before trying to mess with the 12 inches of snow/slush/water.
Oh yes.. one thing I recently discovered is how to decipher the model number.
I think this is right...
T7-2-24-40955
T7 => 7 HP
2 => Two Stage
24 => 24 inch clearing width
40955 => Serial number
OK I've put these three Bobcats off for long enough.
This is in the best condition so I thought I'd start with this one.
Everything seems OK except the "fast-slow" gear lever is stuck in "fast"
Ideally I'd like to get that working because it's a little aggressive stuck on fast.
Are there any tips and tricks before I jump in and randomly start taking things apart?
Additional Photos: https://photos.app.goo.gl/Iaf3yF1xidG5yp3g2
