I'm having a very hard time finding any kind of parts diagrams for an old Bolens 524. I need to replace the belts and the ones on there now were probably just bought because they were close, but aren't riding the pulleys right. Was this model called something else or is there a comparable model under a different brand that I could find parts diagrams for? Or does anyone have the correct belt numbers? There's a drive belt and an auger belt.
Thanks.
taylor, I cant help you, other than to offer.....Post a good picture showing the complete unit and someone should offer advise.....U on the correct site...
I would measure current belts...Drive then auger.
These work for 624 worth a try....measure your current ones and see if similar.
Drive belt: 31"=1751601 or 32" 1739943
Auger belt: 38" 1739944
I actually contacted Bolenspartsandsupplies.com and they just replied and said that belt 1894272 is the drive belt, and it's a cog type. Belt 1725253 is the auger v belt. The belts that were on there were close, but not correct, so I wanted to make sure before buying them. If anyone has any kind of parts breakdown of a Bolens 524 (Might be 524-10), I'd appreciate getting a copy.
