i dump picked an MTD/Yard Machine chipper over the weekend. when i checked the oil, the dip stick/funnel looked like butter. when i warmed it up and drained it the fluid came out grayish. i believe this machine is from the mid '90's, not sure about the engine (there was another tecumseh engine with it that may have been the original.
this engine seems to have two yellow fill plugs and two different types of drain plugs. not sure if this is unusual or not. for all i know the oil is original. was going to do an oil change. should i do a temp change with a cleanser fluid to clean it out, or maybe two oil changes?
