1 - 14 of 14 Posts
I have a Motion Pro one just like the one in the picture, and use it regularly on just about any machine with cables.
A good quality cable lube is also important, as you want to ensure you "push" the moisture out.
Youtube has some great show and tell on their use.
Six cables on the Yammy, just gave them a treat.
I would have put it in the same arena as a squeegee sharpener.
Thanks - keep it in mind.
Used mine this weekend on my Honda lawn mower. I know of no other way to lube a cased cable. Genius!
Colby,
While on the topic of cables... I have a YS928J (like yours I think)... Lately, when I try to adjust the pitch of the chute, it seems the mechanism is slow to respond. I'm thinking the chute cable needs to be tightened. Where/how do I tighten the chute cable? Under the control console, or where the cable meets the chute? Is it simply a matter of tightening that nut just below the plastic casing?
I my case I ordered a new cable because it is damaged. You adjust under the console.
1 - 14 of 14 Posts
